Peat
Dear Fellow Riders,
Picture this: The wind is in your hair, the dusty road is hugging your tires, and freedom is the theme of your day. Until the moment you need to take a break and what should be a simple stop turns into a muscle-straining saga. You push down your side stand, start to lean the bike, but then it leans too far. That momentary panic hits as your left leg scrambles to bear the weight of your two-wheeled companion—because, of course, the stand found the only hole on this sandy road.
If this scenario sounds all too familiar, it's time for a hero to enter your story: The Sidekicker.
With just a press on the cleverly designed serrated foot, the Sidekicker telescopes to perfection, anchoring your bike securely—even in the trickiest of terrains. No more undignified dances with gravity. No more pleas to the motorcycle gods to spare you embarrassment. The Sidekicker is your steadfast pal, one that's been meticulously engineered to adapt to your world's ups and downs.
How is Sidekicker different, you ask? Here's the game-changer:
Robust Construction: Crafted for the long haul, our heavy-duty design gives you peace of mind.
Versatile Compatibility: Whether you're mounting a featherlight flyweight or a behemoth cruiser, the Sidekicker's got your back (or, should we say, your bike).
Adjustable Reach: That's the marquee feature. Extend the Sidekicker's reach with just a nudge, and your bike rests as if it's on terra firma, anywhere.
This is more than just a side stand; it's an upgrade to your entire motorcycling experience. No need to scout for the perfect parking spot anymore. The Sidekicker's got the flexibility of a gymnast and the strength of a weightlifter.
Don't let a little lean-angle issue deface the ride of your life. Make the smart switch to the Sidekicker and watch as your bike stands as proud as you are, ride after ride.
Are you ready to revolutionize the way you rest your ride? Shift your journey into a higher gear of convenience and security with the Sidekicker – where each stop is just as smooth as the last mile.
Ride on with confidence.
Price R1500 onco.
Price R1500 onco.
