Skipskop
I'm having hard starting problems and decided to check the tappets.
I found this pin protruding from the exh cam. When it passes the follower is exactly when the valve is closed and you should adjust the tappet but the protruding pin rides on the follower, is this right ?
I know here are some good knowledgeable guys here and am looking forward to some interesting answers .
